b2gadmin
After installation of DBTech Advanced Post Thanks Like lite v1.1.2 or Advanced Post Thanks Like Pro v1.1.2 our CometChat 2.0.4 integreation fails to load avatar images.
We can uninstall or disable the post thanks mod and the avatars load again which seems to indicate that something in the dbtech code is the cause.
The CometChat has an integration file called ccpic.php
If this file is placed in the root of a forum that does not have the dbtech mod installed it displays an image when called directly with http://<domain name>/ccpic.php.
After the dbtech mod is installed the following error is displayed:
Fatal error: Cannot redeclare resolve_cp_image_url() (previously declared in /www/band2gether/ccpic.php:36) in /www/band2gether/includes/adminfunctions.php on line 3929
You can obtain this file from cometchat at:
http://www.cometchat.com/extra/ccpic.zip
The problem does not exist in the DBTech code per say; for some reason unknown to me, that file blocks the normal permissions fetching in vBulletin, which is confusing APTL, causing it to try to rebuild its permissions (which requires that file).
Could you provide me with an FTP account that can access that file so that I can properly figure out a permanent fix for all other modifications running similar code?
Do note that APTL needs to be active while I perform my tests :)
Nevermind, I found out that Trekkan (whom we host) use it as well and has the same problem, so I can debug it right on our own server :)
Will post back when I have a solution :)
I've found a solution, it will be part of the bugfix rollup releases I plan to make tonight :)
