iRoush
Hello All. The issue that I'm having is only having 3 options to change in the AdminCP of my website, when it says I should have many more. It's a fresh install with all files needed. These are the only options I have in the AdminCP>Settings>Options>DragonByte Tech: vBShout - General Options
1.)Display Version Number
2.)Enable vBShout
3.)Reason For Turning vBShout Off
Am I missing a page where the other options would be? Thank you!
Look in the sidebar on the left for DBTech - vBShout that is where everything else is, also make sure you are set to super admin in config.php
that probably explains it. I have to be superadmin to be able to view it? I'm just an admin as of right now (I don't own the site, just fixing errors that the previous web admin caused) and I'm not seeing that bar on the side.
Yes in the left side of the ACP, or be set to administer vShout in Administrator Permissions
perfect, thanks ozzy I located the settings.
Is there a way to increase font size and possibly move the text box underneath the chatbox?its taking up a lot of space for no reason on the side. Thanks!
For the text size you need to make sure Allow Size BB Code is ticked in instance management.
Controlling shout input area location is a pro only feature.
