Question vB Optimise: Guest Caching Comment?
Badger
Ok, so I turn this option ON and looked at our forums as a GUEST ..
If you wish, vB Optimise can add a html comment to all pages served to guests which are cached before the </body> tag.
The format of this tag is as follows:
<!-- vB Optimise Guest Cached Page / Generated in [x.xxxxx] seconds with [y] queries and [z] queries saved vs uncached -->
Where do I look to see this information? I can't seem to find it displayed? :confused:
Thanks .. :)
Regards,
Doug
It only shows up for guests, and it's a HTML comment so it would not be displayed anywhere except in the source code :)
