Question Redemptions not being awarded
scottkoz20
hello team -
I am trying to get the redemption codes and links working for my site. I would like to use this to trigger some rewards for projects that I am working with on my site at this point.
When I try to use the code that is generated, which is https://www.sportscardforum.com/credits.php?code=2RMSO2X5 - it does go to the link that set for the redirect; however the credit is not being pushed out. I have it set to set 1 credit (called Reward Points on sportscardforum.com).
I have it listed as a question to make sure that I'm not doing something wrong on the setup. If you need something, please advise
Scott
Does it work if you go through the normal currency menu and enter the code manually?
forgive my ignorance on the answer - are you referring to this screen? If so, all I see if Transfer and Adjust
8801
Ok - I have the redemption option available and I can put in the code with optional comment
When I use the same code in the URL, that did not work, but another code did.
Today, 09:14 AM
Redeem
Earned 1.0 SCF Rewards
scottkoz20 used D0CWHF36
Today, 09:13 AM
Redeem
scottkoz20 used 2RMSO2X5: testing
Thus the reason I put it in as a question and not a bug is I was positive the problem was between the chair and the keyboard ;)
Hello @scottkoz20,
We hope your ticket regarding vBCredits II Deluxe has been addressed to your satisfaction. This ticket has now been scheduled to be closed.
Question btc icon?
Legacy vBCredits II Deluxe
