Question Post thanks over SSL
Gumble
Trying to get rid of the insecure message
Not sure where to change
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.min.js"></script><script type="text/javascript"
To the https
Tkx
That would have to be a file edit. I believe it's in /dbtech/thanks/hooks/showthread_complete.php
Is there a way to detect whether your forum is running in SSL mode or not? If you have any advice to offer me I may be able to implement it into the next version automatically :)
Thanks for fast reply.
Yeah just edited the file and the error as gone.
I was trying to figure about it not sure if is possible to put some rule like replace http:// for bburl would or is possible to work.
Just have set the SSL today still a bit lost about it :)
Hmm, I'll have a dig through the files to see if there's any way to detect it automatically, that'd be preferable :)
Update: Found it:
REQ_PROTOCOL === 'https'
I'll be updating mods with this change over time :)
