IcEWoLF
http://dragonbyte-tech.com/ (shows users are logged out) when logging in users get the following error: Invalid Redirect URL (http://dragonbyte-tech.com/)
Redirect should be set tohttp://www.dragonbyte-tech.com/
in the htaccess file for vbseo just remove #:
# Comment the following line (add '#' at the beginning)
# to disable mod_rewrite functions.
# Please note: you still need to disable the hack in
# the vBSEO control panel to stop url rewrites.
RewriteEngine On
# Some servers require the Rewritebase directive to be
# enabled (remove '#' at the beginning to activate)
# Please note: when enabled, you must include the path
# to your root vB folder (i.e. RewriteBase /forums/)
#RewriteBase /
[COLOR="#FF0000"]#[/COLOR]RewriteCond %{HTTP_HOST} !^www\.yourdomain\.com
[COLOR="#FF0000"]#[/COLOR]RewriteRule (.*) http://www.yourdomain.com/forums/$1 [L,R=301]
RewriteRule ^((urllist|sitemap_).*\.(xml|txt)(\.gz)?)$ vbseo_sitemap/vbseo_getsitemap.php?sitemap=$1 [L]
RewriteCond %{REQUEST_URI} !(admincp/|modcp/|cron|vbseo_sitemap|api\.php)
RewriteRule ^((archive/)?(.*\.php(/.*)?))$ vbseo.php [L,QSA]
RewriteCond %{REQUEST_FILENAME} !/(admincp|modcp|clientscript|cpstyles|images)/
RewriteRule ^(.+)$ vbseo.php [L,QSA]
