Question Is it Possible?
soso
I am using Double ended for short answers, my problem is if the answer has 5 or 6 words like "The man who fell to earth" as the answer and someone answers "The Man Who Fell To Earth" it is marked as wrong! Can't quizzes be made without being case sensitive? :(
You sure the answer matches exactly? I just checked on my dev and it's working correctly. It's been case insensitive since the start.
No, this is my question, i don't want the answers to be case sensative. If the answer is ..Lets say "Numbers" and someone puts "numbers" then it should be marked as correct? This is what i am asking ... :(
It's been case "insensitive" since the start.
Meaning it should not matter on the case of the text.
Yes, sorry, I meant matching exactly as in the spacing, spellling, etc, not the case. If the answer is "The Man Who Fell To Earth" then "the man who fell to earth" or "tHe maN Who fELl to EaRtH" should match as correct. I convert both to lower case before I match them against each other.
Sorry, you are both right, the reason no points were given was because i had not given the answers any value ... :rolleyes:
Legacy vBQuiz
