Bug Info Stats Module
Shimei
Hi,
I tried to enable info stats module in my vbulletin 5.1.9 website. I have disabled it at the moment, and will enable it when someone is able to get to it.
I had problems with the info panels and someone here had gone into my site and fixed it, also saying that I did not need to update because of what they had done.
The info stats however, just says loading..... and nothing happens.
Here's a link to my site: Christian forums
When someone is able to work on this or suggest what to do I will enable the module or they can themselves.
Thanks,
William
Please disregard....
I was attempting to run two stats modules... when I wanted the welcome panel.
Everything works properly.
Thanks
Hello Shimei,
Legacy InfoPanels
