Bug High memory usage and execution times
pmraiders
We are experiencing high ram usage and high script execution times from dbseo.php. These warnings are being reported by lfd on cpanel. Memory usage of ~760mb and execution times of ~30 seconds are being reported.
Please let me know how I can go about investigating this issue.
This is incorrect. LFD gives DBSEO the "blame" for all your resource usage because DBSEO will load vBulletin once it's resolved the URL.
Think of it this way:
With DBSEO:
dbseo.php -> showthread.php OR forumdisplay.php OR forum.php [...]
Without DBSEO:
showthread.php
forumdisplay.php
forum.php
You should not trust LFD or any other monitoring script that can't tell the individual memory usage of each included PHP file, and if your host tries to tell you it's DBSEO's fault then you should search for a better host.
