alhidaya
I installed version 4.2.0 and I don't see vbquiz on the navbar. I réuploadé but still nothing. The vbquiz disappeared from the navbar and does not want to reinstall
Why we no longer see on my navbar vbquiz since the update vbulletin 4.2.0? What should I do?
Our modifications have not been officially tested & updated for v4.2 at the moment, they will be updated over the coming weeks. At the moment you can manually add the tab using vBulletin 4.2s new NavBar feature - instructions on how to use this feature should be included with your forum/update.
I just added a new bugfix version of vbquiz that should add the navigation buttons again. Let me know if it doesn't work for you.
Hello
I upload the file vbquiz 1.2.4 ... Thank you: that's great. Good job and very fast. It's good to trust you.
A quick update, I think I will opt for other products from you.
good luck
See you soon
