Bug Bug ? Link to post on vbcredits
When you disable vbseo, does the link switch to something that works? (you can reenable vbseo after checking that for me)
Unfortunately, this is a bug with the link rewriting on your site by vBSEO (otherwise the link would still be broken when vbseo is disabled).
Send vBSEO a before and after of the link for them to determine how you can fix it. They should be able to identify what you need to do.
Legacy vBCredits II Deluxe
