I just updated to 4.2.0 and it finally implemented a "Navigation Manager" to control tabs, but it's lacking what vBNavTabs has to offer in the way of icons for tabs, sub bars, etc. When I installed this, it overwrote what vBNavTabs did.
I tried to disable/enable the plugin to overwrite it, but in the heat of the moment I had to create new tabs to keep the site the same.
Is there going to be an update for 4.2.0 to make this replace the nav bar?
Thanks
Thanks
