Question How Do I Create a Drop Down with Navigation Manager
thunderclap
I see I'm suppose to use the Navigation Manager in vB 4.2, but I don't see a way to create a drop down. Is it possible with the free version?
That is default functionality in the Navigation Manager in vB 4.2.1 and above.
It is a small process but not to difficult.
1) Create a tab.
2) Create a menu for the tab.
3) Edit the tab and find the setting, "Target Menu" select the menu you just created, click on save.
4) Add links to the menu you created, these are what will show up as the dropdown items in the tab.
Fillip H.
Can admin make the above that Ozzy posted a sticky in light and pro sections would be nice for those that are looking for this how to to reference it thanks
Legacy vBNavTabs
