Dej
Hello.. 3 questions.
1) I only need the Awards portion of this mod - is it possible to disable the Activity features?
2) Also, I'm using another Awards mod right now, which I have to disable because it's quarantined at vbulletin.org - not sure if I can mention the name of it here, so I won't.
But, here's what my postbit looks like now. Will I be able to stack multiple awards - and code them below the DragonByte "Advanced Post Thanks / Like" mod?
3) Does the mod work on both 4.1.10 and 4.2? I ask because I'm going to upgrade to 4.2 in a couple months, and I'd like to know if the mod will transition smoothly when I upgrade.
Thanks
Could you please edit the issue above and enter the URL of the website you intend to run the product on.
Please note that an incorrect or invalid URL will mean we are unable to provide support.
Only DBTech staff see your URL.
You can, yeah :)
Note that the Achievements and the Promotions (Pro-only) features are dependant on the Activity portion - so those features would also be unusable if you decided to disable points accumulation and display.
By default it does do that yeah :) Only the icons are on the same line, and by default they are small squares. But if you add replacement Award images to those banners, I suspect it would line wrap them as well.
You will need to re-import the product XML file when you upgrade to 4.2, same with every other mod you have installed that lack the navigation manager entries :)
See the "Contributor" icon in Ozzy's postbit? Is that part of the Awards mod, or is just HTML in Admincp > User Manager > User Title?
