Robbed
I just purchased the pro version. Is it possible when i disable a certain settings sound, private messages etc it doesn't show up in the usercp. I don't want them asking for features we decide to disable.
Is there a setting to auto prune logs and archive.
Thanks
Thanks
It shouldn't be to hard to add, hopefully something can be done for the next update. Guess I can edit the template manually for now.
So what happens if they enable private messaging or sounds when it's disabled in the admincp. Does it just not work?
small issues.
With IE at the bottom where it says shout to everyone it shows [256]
When I click Shoutbox Settings in usercp it moves my footer under the menu on the left instead of a the bottom of the page.
[256] is characters remaining.
I am unable to confirm the footer issue so it may be an issue with a customised skin. Please create a clean unmodified skin on your forum and see if the issue persists.
Question Weird
