Bullmama DeLano
I have this in lite and pro versions, so I have tested and confirmed it happens on both and on various test forums.
If I create a new widget or try to edit or configure a new widget, it breaks the widget completely. (see photo)
If Super PMs is disabled, there is no problem. I have no idea why this product would mess up widgets, but it does!
Even with product disabled, the widget will not come back. All widgets must be created and edited with this mod disabled. It will break ANY type of widget too. Not just html.
Hope you can get this bug fixed, because although I know the problem exists, and how to get around it, I do not always remember, and end up breaking widgets again. :embarrassed: Thanks!
