Question Title forums with žćđš
Dora
Boards that have the title šćžđ not to work if placed on "[forum_title] /" or "[forum_title]. Htmll"
Supaz works
Šupaž back to 404
If you choose "forum [forum_id] /" does everything but write forumxxx when clicked.
This is a test copy of the original forum on the same server.
Tried, turn off all modules except Seo, uninstallation of all modules except Seo, all combinations htacces etc. ..
new test copy of the "default" on the same server works all ok so the title gag with šđžćč letters.
Please help, I like the module but does not work the way I want.
I have FTP and admin account, I can send parameters to the PP if anyone wants to look.
thanx,
I strongly recommend adding the ID to forum URLs (and all other URLs that are optional, like Members) to avoid compatibility issues like these. You can also try enabling UTF-8 if your forum is set up for this.
This is not a bug.
Please clarify
Think ID as a "forum [forum_id] /"?
UTF-8 is enabled, everything else works, blog, members, articles, edit etc. ..
With the option "forum [forum_id] /" everything works ok, and forum title with šćčž ....
link is mysite.com/forum122 /
I wanted the link mysite.com / forumtitle /
If the "[forum_title.html]" option is choosen than the forum works normaly without ŽĆČ letters. But with those letters included it drops back to the Home Page of the forum.
Freshly installed a forum on the same VPS server works exactly as I wanted, was chosen "[forum_title.html]" and a link to the forum is mysite.com / đževrek-of-đumbira.html
NOS work
http://vbtest.cbc.rs/obaveštenja.html not work
Update: Rewrites are currently failing on your test forum because the "datastore" table cannot store the forum cache in a correct format. You may wish to ensure that this table and both its columns are utf8, and if so, use HTML Entities for the Polish characters instead of typing them outright.
This may also resolve the DBSEO issue, but currently I am unable to assist you with this issue.
Okay, thanks for your interest ..
I wiil not delete the User. It would mean to us a great deal if You would be able to help us if You have some time to spare.
I don't understand what you are referring to when you say you won't delete the user.
In either case, this is not something I will be able to assist you with, sorry :(
