Question Thread Tagging and Massive Database Queries Causing Problems
highlander
I have had really high hopes for the thread tagging functionality but I haven't been able to get it to work on my forum. It works correctly in that it applies thread tags. I love the functionality to have a list of keywords to do the tagging with.
The problem relates to VBulletin Tag Cloud. I have a large forum (2.4M posts). I have tried tagging threads several times and .the result is always the same. I have significant performance issues and massive number of unindexed database queries. Here is a thread where I first reported the problem.
http://www.dragonbyte-tech.com/f239/posts-not-showing-up-15688/
It is less severe if I tag a smaller number of threads. For example, when I applied thread tags to all seven years worth of threads, it caused significant issues. When I applied it to only 8 months of information, it did not cause the missing posts but there was still a noticeable performance degradation. As best as I can determine, this is caused by the Tag Cloud. I have tried every setting I can think of to get tag cloud functionality to be off but can't seem to get it to work. The performance problems and missing posts issue goes away when I remove the thread tags.
Can you provide some specific recommendations on this?
DBSEO has no control over the vBulletin Tag Cloud and unfortunately I don't know of any way to optimise it, sorry :(
