Question Simple Way To Employ Lots of Places?
iMaverick
Hey, so essentially I want the Shoutbox absolutely everywhere, and while so far I've just been editing a milltion templates, there are a couple where it's difficult for me to find the navbar link (to add my thing underneath it).
Is there some sort of expedited process for doing this?
Thanks!
If you want it in all locations then all you have to do is manually add it to the navbar template as per the instructions :)
The very bottom should show it beneath the vBulletin Notices, or you can put it directly beneath the ad_location.global_navbar_below or whatever in order to put it above the vB Notices :)
The Instructions are in Editing Instance: Live Chat
The second box where it says Display settings:
Auto-Display Shoutbox This setting controls whether the Shoutbox will automatically be added to the "Forum Home".
Selecting "Disabled" means you need to add a variable to all relevant templates manually.
If you wish it to display on all pages, add the code as per the description of the "Varname" setting above to the navbar template.
