Bug Raffles Issues
Website
http://absolutegaming.co.uk/forums
Product version
1.0.0b1
Forum version
vBulletin 4.2.x
#1
Couple of issues with this.
Cant see the pro forum after purchasing a 1 year on this product.
Also after setting up it seems as though there is no option to buy a ticket. Tried with both the default points and credits but cannot see the enter raffle link on either page.
Also got the following databse errors
Database error in vBulletin 4.2.2:
Invalid SQL:
UPDATE vbdbtech_raffle_entry SET
### UPDATE QUERY GENERATED BY fetch_query_sql() ###
`prize` = 'a:3:{s:9:"prizetype";s:6:"Payout";s:6:"amount";s:4:"1000";s:10:"currencyid";s:1:"2";}',
`prizedisplay` = '1000 Scudo'
WHERE entryid =;
MySQL Error : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 6
Error Number : 1064
Request Date : Saturday, December 27th 2014 @ 01:31:39 PM
Error Date : Saturday, December 27th 2014 @ 01:31:40 PM
Script : http://************************cron.php?rand=1419687098
Referrer : http://**********************raffle.php?categoryid=1
IP Address :
Username : Unregistered
Classname : *************
MySQL Version :
Belazor
Staff member
Owner
Developer
Make sure the user has enough Credits relevant to the entry cost, and also make sure the Start Date of the raffle has passed.
Belazor
Staff member
Owner
Developer
#7
All done. Thanks again
Belazor
Staff member
Owner
Developer
I have been busy with spending time with my family for the Xmas/NY holiday, and travelling from said engagements. I will post back when I have an update :)
Belazor
Staff member
Owner
Developer
Update: The FTP information you have provided does not work, I am unable to connect to your server. Additionally, the AdminCP account does not have the Can Administer Raffles permission, so I am unable to inspect your configuration.
However, I notice you are running Beta 1. Could you please update to the latest version (Beta 2 at the time of writing)? It's possible your issue has already been fixed by other changes :)
#11
Just checked the details I gave you and everything is working correctly so no idea why you cant get the access.
Have updated to the new version with still no change in the issues above. In fact more have been created as you now cannot delete a raffle in the ACP. Gives an error of Invalid.
Have sent you another PM with some details.
Belazor
Staff member
Owner
Developer
I will check the new details and get back to you A.S.A.P., I am currently quite swamped but I'm hoping to clear out my backlog either tonight or tomorrow. Sorry :(
DragonByte Raffles
