RicaNeaga
Is there an option for this mod to show also the number of Dislikes that a user has received in time, alongside its number of Likes and of Thanked posts?
Sorry if I haven't seen the answer elsewhere. I'm interested in buying this product. :)
By default it comes with a Dislike button as well, and if you click through the "dots" in the postbit here on DBTech you'll see a list of stats:
Thanks (Given): 2
Thanks (Received): 0
Likes (Given): 0
Likes (Received): 0
Dislikes (Given): 0
Dislikes (Received): 0
Test (Given): 0
Test (Received): 0
(Your stats :))
Ok, thank you very much for your answer. I have another question however :D
Those dots are also generated (from what I can figure out) by other products / mods. Can I add those Thanks / Likes / Dislikes stats to the default vbulletin dot, that has user stats like age, no of posts etc ? I mean can I use a single stats user window / dot for my forum, that includes both the default stats (vbulletin implicit ones) and the ones generated by thanks / dislikes/ likes?
If yes, can anyone give me a link for a working site that has this kind of implementation? :) Thank you in advance. ;)
Ah, the "dots" are from our Postbit Tabs product and not a feature of APTL.
You have the ability to create and rearrange "dot" (tab) contents at will, with that mod, and it supports most of DBTech's mods out of the box :)
