Sarab
Couple of problem xD
1- the brand free don't work ="(
2- who login the last 24 hours don't work right, user appear and disappear every some minute xD
Best regards,
Sarab
Branding Free issues are something we're aware of, and will be correcting in an upcoming update.
If your cache system is getting full, that can account for the issues you're experiencing. Please ensure you've allocated enough memory for your cache system.
Okey can't I remove it manually from one of the php files?
How can I now the space allowed for Filecache type?
Ah, that should be plenty.
Does it work if you disable the caching of Who Has Visited?
Yeah work fine when I disable this option =D
I did read that APC cache is the best, so can you tell me what should it setting be on the server for best prefomance?
Right now it's:
From a quick glance, those stats look fine. If there's any issues, your host will be able to advise further :)
