GoodApples
Version 1.0.0b4
Added - permission check on sidebar, cms widget and forumhome block
Some elements are viewable
Guest can view...this is what is being displayed.
cms widget
forumhome block
It would be better if it did not display at all.
Did I miss a setting...?
The permissions check I put in is for multiple galleries. If you have say 5 galleries and a user can only see 2 of them, then they will only see images from those 2 galleries. I'm not sure if I can put in permissions on if someone can see a cms block or not, I'll check through for a way to set the groups that can view the block at all and not display it at all if they can't.
Okay, FYI
I was also referring to the sidebar forum block and not the top forumblock displayed at the top of the forum.;)
Okay, FYI
Yeah I know :)
I can set permissions to not display the sidebar block and forumhome block, but I can't figure out how to do it for the CMS. Not sure if it's possible, I'll keep checking though.
Look at the Easy Article Management mod, as I have conditionals for the block and widget.
Brad via Tapatalk
ah cool thanks, so it doesn't show the block at all? I'll get that fixed up before I release then :)
Legacy DragonByte Gallery
