Question Loading problem
Kane
After updating to the latest VBshout release today I am getting the dreaded loading.... issue - only on one of the two enabled instances.
Chrome
Uncaught TypeError: fetchElem(...).on is not a function(anonymous function) @ vbshout.js?v=6216:9(anonymous function) @ vbshout.js?v=6216:373
vbulletin-core.js?v=422:11 Fire vB_XHTML_Ready
Firefox
<anonymous>
 vbshout.js:9
<anonymous>
 vbshout.js:1
This particular instance only relays new posts and threads, no other chat type features are enabled and it was working before the upgrade. Oddly enough the second instance which is chat only is working just fine.
How to fix?
Hi there,
In this particular case, this means that your site is loading a very very old version of jQuery prior to vBShout loading.
I am noticing two potential causes for this problem @ your site:
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.6.4/jquery.min.js"></script>
<script type="text/javascript">
$(document).ready(function() {
	$('a.login-window').click(function() {
		// Getting the variable's value from a link
		var loginBox = this.hash;
		//Fade in the Popup and add close button
		$(loginBox).fadeIn(300);
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.6.2/jquery.min.js" type="text/javascript"></script>
//<![CDATA[
function ShowHide(){
$("#slidealert").animate({"height": "toggle"}, { duration: 1000 });
</script>
Could you please update these copies of jQuery to at least 1.7.1?
Thanks!
Hello Kane,
