Bug [vB 4.2.x] Stuck on loading...
Website
http://small-town.net
Product version
6.2.18
Forum version
vBulletin 4.2.x
#1
Yes. This issue does in fact still occur on the default skin. Although, when I check my console I get this error;
vbshout.js:9 Uncaught TypeError: fetchElem(...).on is not a function
    at vbshout.js:9
    at vbshout.js:373
This is the URL at which the error is pointing to
http://small-town.net/dbtech/vbshout/clientscript/vbshout.js?v=6218
Edit;
I found the issue. Another one of my plugins had broken the shoutbox. The plugin is called Steam Mini Profiles. Anyway for this to be fixed?
Add-On Releases - Steam Mini Profiles (For Steam Connect) - vBulletin.org Forum
Belazor
Staff member
Owner
Developer
That will happen if that plugin is using a very old version of jQuery. I would inspect the templates that mod adds and see if you are able to change the jQuery version to 1.7.1 or newer.
#3
I know very very little about website. Just enough knowledge to work around with them. I found this in the product.xml
http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js
Although, I feel that has nothing to do with the jQuery version. Could you assist me further?
Edit;
So that was it and is now fixed. Appreciate it!
Company Information
Staff member
Company Info
#4
Hello Sir Klutch,
vBShout
