Question IN ACP I only get option for general settings
maphorn
Hi,
I have just purchased and installed DragonByte Tech: vBNavTabs (vB 4.2.0+).
It shows on the ACP but when I expand it only shows general settings
None of the other menu options
vBNavTabs Configuration
Manage Tabs
Manage Dropdowns
Manage Sub-links
General Settings
Images for DBT Products
come up???????
I updated the
|| 4. Second Navbar Template Edit ||
1. Open the Navigation/Breadcrumb Templates, then open the navbar template.
2. In that template find:
</div><!-- closing div for above_body -->
3. Before that bit of code add this:
<!-- start navbar2 -->
<vb:if condition="$vboptions['dbtech_vbnavtabs_navbar2']">
<div id="navbar2" class="navbar" style="margin-top:0px;">
<ul id="navtabs" class="navtabs floatcontainer" style="border-bottom:{vb:stylevar navbar_tab_border};">
{vb:raw template_hook.navtab_two}
</ul>
</div>
</vb:if>
<!-- end navbar2 -->
4. Click on the save button.
Please help.....
Thanks,
Marc
OK now understand previous post - You need to click EDIT from ACP Nav manager then you get the options!
I was looking in the drop down options!!!!
Duh!
Yeah in vB 4.2 they took lot of what was in the mod and added it to the Navigation Manager, so there was no need for all the extra stuff. Glad ya found it though. :)
Legacy vBNavTabs
