Bug Importing donations from XFApp's Donation Mod fails
Knight
Attempted to import some donations from XFApp's Donation Manager and was met with this error. Currently on 3.0.0 Beta 7. I'm assuming it's an issue with my hosts configuration rather than an issue with Xenforo or DB's Donation mod? After failing to import, I just get met with this same error when disabling the plugin, enabling it, or trying to update to 3.0.0 beta 8.
An exception occurred: Mysqli prepare error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 3 in /home1/crazime/public_html/forum/library/Zend/Db/Statement/Mysqli.php on line 77
Zend_Db_Statement_Mysqli->_prepare() in Zend/Db/Statement.php at line 115
Zend_Db_Statement->__construct() in Zend/Db/Adapter/Mysqli.php at line 381
Zend_Db_Adapter_Mysqli->prepare() in Zend/Db/Adapter/Abstract.php at line 478
Zend_Db_Adapter_Abstract->query() in XenForo/Model.php at line 219
XenForo_Model->fetchAllKeyed() in DBTech/Donate/XenForo/Deferred/MercImport.php at line 138
DBTech_Donate_XenForo_Deferred_MercImport->getGoalsNotInRange() inDBTech/Donate/XenForo/Deferred/MercImport.php at line 39
DBTech_Donate_XenForo_Deferred_MercImport->execute() in XenForo/Model/Deferred.phpat line 295
XenForo_Model_Deferred->runDeferred() in XenForo/Model/Deferred.php at line 429
XenForo_Model_Deferred->_runInternal() in XenForo/Model/Deferred.php at line 374
XenForo_Model_Deferred->run() in XenForo/ViewRenderer/Abstract.php at line 354
XenForo_ViewRenderer_Abstract::hasManualDeferredToRun() inXenForo/ViewRenderer/Json.php at line 147
XenForo_ViewRenderer_Json::_addDefaultParams() in XenForo/ViewRenderer/Json.php at line 185
XenForo_ViewRenderer_Json::jsonEncodeForOutput() in XenForo/ViewRenderer/Json.phpat line 37
XenForo_ViewRenderer_Json->renderRedirect() in XenForo/FrontController.php at line 635
XenForo_FrontController->renderView() in XenForo/FrontController.php at line 176
XenForo_FrontController->run() in /home1/crazime/public_html/forum/admin.php at line13
Have you tried uploading the files for Beta 8? That error will only display when actually attempting to run the import, it doesn't affect upgrades.
Yeah, that was fine. Upgrading the XML though gave me the same error. I had to remove the DB entry for the rebuild in xf_deferred to get the upgrade to complete successfully. Unfortunately, when trying to import the donations, it still gives me the same exact error.
I've resolved the error and completed the import, I left the old donation mod disabled.
Sorry for the inconvenience :(
Fantastic, thank you!
If you don't mind me asking... what was the error? I'm assuming it was something on my end.
edit: Errr, one more thing. Went to add a donation drive, and now I'm getting this error.
Mysqli prepare error: Unknown column 'payment_profile_ids' in 'field list'
Zend_Db_Adapter_Abstract->query() in /home1/crazime/public_html/forum/src/addons/DBTech/Donate/Application/Db.php at line 780
DBTech\Donate\Application\Db->query() in /home1/crazime/public_html/forum/src/addons/DBTech/Donate/Application/Db.php at line 403
DBTech\Donate\Application\Db->insert() in /home1/crazime/public_html/forum/src/addons/DBTech/Donate/Application/Entity.php at line 1009
DBTech\Donate\Application\Entity->_save() in /home1/crazime/public_html/forum/src/addons/DBTech/Donate/Application/Entity.php at line 939
DBTech\Donate\Application\Entity->save() in /home1/crazime/public_html/forum/src/addons/DBTech/Donate/ActionAdmin/Drive.php at line 288
DBTech\Donate\ActionAdmin\Drive->actionUpdate() in /home1/crazime/public_html/forum/src/addons/DBTech/Donate/Application/Core.php at line 173
DBTech\Donate\Application\Core->runAction() in DBTech/Donate/XenForo/ControllerAdmin/Donate.php at line 31
DBTech_Donate_XenForo_ControllerAdmin_Donate->actionIndex() in XenForo/FrontController.php at line 369
XenForo_FrontController->dispatch() in XenForo/FrontController.php at line 152
XenForo_FrontController->run() in /home1/crazime/public_html/forum/admin.php at line 13
You can resolve that by running this query:
			ALTER TABLE `xf_dbtech_donate_drive`
				ADD `payment_profile_ids` MEDIUMBLOB
Got it, thanks! Just a note, after setting up the donation drive, I still do not see the old donations from the old donor mod. I see the import thing still works, ran it again to double check, and they're not showing up in the donation log. Am I looking in the wrong place?
Also, tested out payment, which worked, and issued a refund on Paypal to test that, and XF tossed this server error:
ErrorException: Undefined variable: donationId - library/DBTech/Donate/XenForo/Model/DonatePurchase.php:92
#0 /home1/crazime/public_html/forum/library/DBTech/Donate/XenForo/Model/DonatePurchase.php(92): XenForo_Application::handlePhpError(8, 'Undefined varia...', '/home1/crazime/...', 92, Array)
#1 /home1/crazime/public_html/forum/library/DBTech/Donate/XenForo/DonatePurchaseProcessor/PayPal.php(328): DBTech_Donate_XenForo_Model_DonatePurchase->removeDonation(1, '86G88035YB66955...')
#2 /home1/crazime/public_html/forum/dbtech_donate_payment_callback.php(37): DBTech_Donate_XenForo_DonatePurchaseProcessor_PayPal->processTransaction()
#3 {main}
In the database, make sure the old donations have is_test = 0 and is_confirmed = 1.
As for that error, I've fixed it locally. It doesn't affect the functionality as the donation will be removed at that point.
I can't hotfix products right now because of preparations for the XF2 upgrade, and manual patches takes a long time so I'd reserve that for critical issues :)
DragonByte Donate
