Bug DragonByte Shop on Xenforo 1.5.4 Error
randydrew6
I am running Xenforo 1.5.4 and php 5.6.40 and the installation went well, after that i created a shop in the ACP, I accessed the shop index page then went to enter the default shop and the shop I created, both give me this error upon clicking them
An exception occurred: Cannot load class using XFCP. Load the class using the correct loader first. in /home/roguel9/public_html/library/XenForo/Autoloader.php on line 108
XenForo_Autoloader->autoload()
spl_autoload_call() in WidgetFramework/XenForo/View1.php at line 4
include() in XenForo/Autoloader.php at line 119
XenForo_Autoloader->autoload() in XenForo/Application.php at line 1050
XenForo_Application::autoload() in XenForo/Application.php at line 529
XenForo_Application::resolveDynamicClass() in XenForo/ViewRenderer/Abstract.php at line 209
XenForo_ViewRenderer_Abstract->renderViewObject() in XenForo/ViewRenderer/HtmlPublic.php at line 71
XenForo_ViewRenderer_HtmlPublic->renderView() in XenForo/ViewRenderer/Abstract.php at line 249
XenForo_ViewRenderer_Abstract->renderSubView() in XenForo/ViewRenderer/HtmlPublic.php at line 68
XenForo_ViewRenderer_HtmlPublic->renderView() in XenForo/FrontController.php at line 605
XenForo_FrontController->renderView() in XenForo/FrontController.php at line 158
XenForo_FrontController->run() in /home/roguel9/public_html/index.php at line 13
After looking in ACP there is 2 error logs that show this:
Request State
Stack Trace
ErrorException: Fatal Error: syntax error, unexpected '/', expecting '{' - library/XenForo/Application.php(528) : eval()'d code:1
Generated By: Randydrew6, 11 minutes ago
#0 [internal function]: XenForo_Application::handleFatalError()
#1 {main}
array(3) {
["url"] => string(61) "https://www.rogue-labs.net/Marketplace/rogue-labs-shop.2/shop"
["_GET"] => array(2) {
["do"] => string(4) "shop"
["id"] => int(2)
["_POST"] => array(2) {
["id"] => int(2)
followed by..
Request State
Stack Trace
XenForo_Exception: Cannot load class using XFCP. Load the class using the correct loader first. - library/XenForo/Autoloader.php:108
#0 [internal function]: XenForo_Autoloader->autoload('XFCP_WidgetFram...')
#1 /home/roguel9/public_html/library/WidgetFramework/XenForo/View1.php(4): spl_autoload_call('XFCP_WidgetFram...')
#2 /home/roguel9/public_html/library/XenForo/Autoloader.php(119): include('/home/roguel9/p...')
#3 /home/roguel9/public_html/library/XenForo/Application.php(1050): XenForo_Autoloader->autoload('WidgetFramework...')
#4 /home/roguel9/public_html/library/XenForo/Application.php(529): XenForo_Application::autoload('WidgetFramework...')
#5 /home/roguel9/public_html/library/XenForo/ViewRenderer/Abstract.php(209): XenForo_Application::resolveDynamicClass('DBTech/Shop_Xen...', 'view', 'XenForo_ViewPub...')
#6 /home/roguel9/public_html/library/XenForo/ViewRenderer/HtmlPublic.php(71): XenForo_ViewRenderer_Abstract->renderViewObject('DBTech/Shop_Xen...', 'Html', Array, 'dbtech_shop_sho...')
#7 /home/roguel9/public_html/library/XenForo/ViewRenderer/Abstract.php(249): XenForo_ViewRenderer_HtmlPublic->renderView('DBTech/Shop_Xen...', Array, 'dbtech_shop_sho...', NULL)
#8 /home/roguel9/public_html/library/XenForo/ViewRenderer/HtmlPublic.php(68): XenForo_ViewRenderer_Abstract->renderSubView(Object(XenForo_ControllerResponse_View))
#9 /home/roguel9/public_html/library/XenForo/FrontController.php(605): XenForo_ViewRenderer_HtmlPublic->renderView('DBTech_Shop_Xen...', Array, 'dbtech_shop_wra...', Object(XenForo_ControllerResponse_View))
#10 /home/roguel9/public_html/library/XenForo/FrontController.php(158): XenForo_FrontController->renderView(Object(XenForo_ControllerResponse_View), Object(XenForo_ViewRenderer_HtmlPublic), Array)
#11 /home/roguel9/public_html/index.php(13): XenForo_FrontController->run()
#12 {main}
array(3) {
["id"] => int(2)
["id"] => int(2)
Can I get some help?
Can you please try disabling all other add-ons? There may be a conflict somewhere, as our add-on isn't actually mentioned anywhere in the error message itself 🤔
I should point out that what with XenForo 1.5 itself being end-of-life and no longer receiving updates of any kind (including security updates), I would strongly recommend upgrading to XenForo 2.1 as soon as possible.
I plan on updating to 2.1 at some point but if I can get everything working on 1.5 I don't see a point yet but maybe when I can afford it I will. It turns out its because my [bd] Widget Framework was outdated thank you very much :)
Hello @randydrew6,
Hello @randydrew6,
DragonByte Shop
5.00 star(s) 3 ratings
