Aljuve
hi
i'm using vBShout lite Version , and i have some question !
1- how i can put vBShout control like ( font - color - send Button ) start from right to left ?
2- and , There are slow to move between rooms , how can i put this Fast ?
1. You'd need to edit the dbtech_vbshout_editortools template, but I don't know what specific edits you'd need to apply. I'll look more thoroughly into this for the next version :)
2. That cannot be done, sorry :(
Update: You can fix it yourself by openin dbtech_vbshout_editortools and change this line:
HTML:
<div class="editor_controls floatcontainer" style="padding:0; width:auto; display:inline; float:left; position:relative;">
to
HTML:
<div class="editor_controls floatcontainer" style="padding:0; width:auto; display:inline; float:{vb:stylevar left}; position:relative;">
i can't find the code
can you do that for help me !
take this :)
HTML:
<div class="texteditor" style="display:inline;">
<div class="controlbar" style="display:inline;">
		$template_hook[dbtech_vbshout_editortools_start]
		<if condition="$instance['options']['editors'] & 32 AND $bbuserinfo['dbtech_vbshout_settings'] & 32"><input type="button" class="button" value="$vbphrase[dbtech_vbshout_clear]" name="dbtech_vbshout_clearbutton" data-instanceid="$instance[instanceid]" /></if>
		<if condition="$instance['options']['editors'] & 64 AND $bbuserinfo['dbtech_vbshout_settings'] & 64"><img src="$stylevar[imgdir_editor]/smilie.gif" alt="$vbphrase[smilies]" width="21" height="20" name="dbtech_vbshout_smilies" data-instanceid="$instance[instanceid]" style="vertical-align:bottom;" /></if>
		<if condition="$instance['options']['editors'] & 1 AND $bbuserinfo['dbtech_vbshout_settings'] & 1"><img src="$stylevar[imgdir_editor]/bold.gif" class="imagebutton" style="vertical-align:middle;"  name="dbtech_vbshout_imagebutton" data-instanceid="$instance[instanceid]" data-button="bold" width="20" height="20" alt="$vbphrase[dbtech_vbshout_bold]" /></if>
		<if condition="$instance['options']['editors'] & 2 AND $bbuserinfo['dbtech_vbshout_settings'] & 2"><img src="$stylevar[imgdir_editor]/italic.gif" class="imagebutton" style="vertical-align:middle;" name="dbtech_vbshout_imagebutton" data-instanceid="$instance[instanceid]" data-button="italic" width="20" height="20" alt="$vbphrase[dbtech_vbshout_italic]" /></if>
		<if condition="$instance['options']['editors'] & 4 AND $bbuserinfo['dbtech_vbshout_settings'] & 4"><img src="$stylevar[imgdir_editor]/underline.gif" class="imagebutton" style="vertical-align:middle;"  name="dbtech_vbshout_imagebutton" data-instanceid="$instance[instanceid]" data-button="underline" width="20" height="20" alt="$vbphrase[dbtech_vbshout_underline]" /></if>
		<if condition="$instance['options']['editors'] & 8 AND $bbuserinfo['dbtech_vbshout_settings'] & 8">
		<img src="$stylevar[imgdir_editor]/separator.gif" width="6" height="20" alt="" style="vertical-align:bottom;" />
			<select name="dbtech_vbshout_colorrow" data-instanceid="$instance[instanceid]">
				$colors
			</select>
		</if>
		<if condition="$instance['options']['editors'] & 16 AND $bbuserinfo['dbtech_vbshout_settings'] & 16">
			<select name="dbtech_vbshout_fontrow" data-instanceid="$instance[instanceid]">
				$fontnames
			</select>
		</if>
		<if condition="$permissions['cancreatechat']">
			<img src="dbtech/vbshout/images/newchat.png" alt="$vbphrase[dbtech_vbshout_create_new_chat]" style="vertical-align:bottom;" name="dbtech_vbshout_setcommand" data-instanceid="$instance[instanceid]" data-command="/createchat " />
			<span name="dbtech_vbshout_chatinvite" data-instanceid="$instance[instanceid]" style="display:none;"><img src="dbtech/vbshout/images/add.png" alt="$vbphrase[dbtech_vbshout_invite_to_chat]" style="vertical-align:bottom;" name="dbtech_vbshout_setcommand" data-instanceid="$instance[instanceid]" data-command="/chatinvite " /></span>
		</if>
		$template_hook[dbtech_vbshout_editortools_end]
</div>
</div>
and when will the elite version end ?
sorry abaut my LANG !
Ah, sorry, I gave the vB4 code instead of the vB3 code.
Find
HTML:
Replace with
HTML:
<div class="controlbar" style="display:inline; float:$stylevar[left];">
That should work :)
Update: In dbtech_vbshout_shoutcontrols find
HTML:
<div style="float:left; display:inline; padding-right:6px;">
replace with
HTML:
<div style="float:$stylevar[left]; display:inline; padding-right:6px;">
That will fix it.
I've tested my latest edit (Post no. 8) with a RTL language and I found it to work. Please ensure you've flushed any cache systems like vB Optimise or vBSEO Cache that you may be running.
Fixed, the template edit I provided in my previous post had been applied incorrectly :)
I asked you to edit it with $stylevar
but instead you added $stylevar
. These stylevars get reversed when you use a RTL language, so $stylevar
becomes right and vice versa :)
