Question Header questions...
Footman
I'd like to change a couple of things with the header if I can...
1- I'd like to change the "# Likes" to "# member(s) like this post"
I was able to find in phrases where I can change the first part to remove the "Thanks" and to only show "Post Likes" - However I cannot find where to change the # Likes phrase.
2- I found the section that allows for color change when the count reaches a predetermined threshold. However I'd like to only change the Post Likes Header background and font colors. Is this possible?
Thank you,
1. Manage Buttons -> Edit -> List Text
2. That's not possible without also changing the post header, sorry :(
Thanks Fillip H..
1- I actually wanted to change the title so I changed the title in there and it worked perfectly.
2- I was hoping it was necessarily the same piece of code. It was a small thought and certainly not a big deal.
Thank!
