Question Fix 500 error
feverc5
I am getting 500 errors on some of the threads and a few of the posts are just redirecting to the main page. It's defiantly something we broke, somewhere down the line. Any help would be much appreciated!
I'm only seeing one error in the error log.
PHP Fatal error: Call to undefined function voku\helper\iconv() in /home/***/public_html/forums/dbtech/dbseo/includes/3rdparty/portable-utf8/voku/helper/UTF8.php on line 455
You need iconv PHP module :)
http://php.net/manual/en/book.iconv.php
Yeah, it's definitely recommended to install iconv and mbstring into your PHP (very easy to do if you are on a dedicated or VPS server with cPanel / WHM). That will ensure everything works as intended :)
Awesome! Thank you. I have installed those two plugins and everything is working in terms of the white pages. However, I am now noticing that more and more threads are redirecting to the homepage. Do you have any ideas?
Do you have your custom 404 handler set up to redirect to home page?
currently I do. It also seems like something with non-latin characters or numbers.
So I have changed it to either of these settings to no avail.
Remove Non-Latin Characters
Replace Non-Latin Characters
Have you changed any other settings recently, such as the UTF-8 settings?
I have look over all the settings we have. It appears they are all the same as they were. We've always had small issues here or there. Now it seems like close to 1/9th of all threads new and existing are redirecting to the index page. What would be causing the 404?
Can you please show me the contents of all your .htaccess files from the top down (e.g. if you have your forum in a subfolder, the root .htaccess file will also affect the subfolder one)?
Htaccess in the root folders. This is the only htacess we've ever messed with (at least intentionally).
<IfModule mod_rewrite.c>
RewriteEngine On
# RewriteBase /forums/
# Options -MultiViews
</IfModule>
#Deny attempts to view the Htaccess file.
<Files .htaccess>
Order allow,deny
Deny from all
</Files>
# BEGIN Browser Caching/Headers
<IfModule mod_mime.c>
AddType text/css .css
AddType application/x-javascript .js
AddType text/html .html .htm
AddType text/richtext .rtf .rtx
AddType image/svg+xml .svg .svgz
AddType text/plain .txt
AddType text/xsd .xsd
AddType text/xsl .xsl
AddType text/xml .xml
AddType video/asf .asf .asx .wax .wmv .wmx
AddType video/avi .avi
AddType image/bmp .bmp
AddType application/java .class
AddType video/divx .divx
AddType application/msword .doc .docx
AddType application/x-msdownload .exe
AddType image/gif .gif
AddType application/x-gzip .gz .gzip
AddType image/x-icon .ico
AddType image/jpeg .jpg .jpeg .jpe
AddType application/vnd.ms-access .mdb
AddType audio/midi .mid .midi
AddType video/quicktime .mov .qt
AddType audio/mpeg .mp3 .m4a
AddType video/mp4 .mp4 .m4v
AddType video/mpeg .mpeg .mpg .mpe
AddType application/vnd.ms-project .mpp
AddType application/vnd.oasis.opendocument.database .odb
AddType application/vnd.oasis.opendocument.chart .odc
AddType application/vnd.oasis.opendocument.formula .odf
AddType application/vnd.oasis.opendocument.graphics .odg
AddType application/vnd.oasis.opendocument.presentation .odp
AddType application/vnd.oasis.opendocument.spreadsheet .ods
AddType application/vnd.oasis.opendocument.text .odt
AddType audio/ogg .ogg
AddType application/pdf .pdf
AddType image/png .png
AddType application/vnd.ms-powerpoint .pot .pps .ppt .pptx
AddType audio/x-realaudio .ra .ram
AddType application/x-shockwave-flash .swf
AddType application/x-tar .tar
AddType image/tiff .tif .tiff
AddType audio/wav .wav
AddType audio/wma .wma
AddType application/vnd.ms-write .wri
AddType application/vnd.ms-excel .xla .xls .xlsx .xlt .xlw
AddType application/zip .zip
</IfModule>
<IfModule mod_expires.c>
ExpiresActive On
ExpiresByType text/css A31536000
ExpiresByType application/x-javascript A31536000
ExpiresByType text/html "access plus 1 seconds"
ExpiresByType text/richtext A3600
ExpiresByType image/svg+xml A3600
ExpiresByType text/plain A3600
ExpiresByType text/xsd A3600
ExpiresByType text/xsl A3600
ExpiresByType text/xml A3600
ExpiresByType video/asf A31536000
ExpiresByType video/avi A31536000
ExpiresByType image/bmp A31536000
ExpiresByType application/java A31536000
ExpiresByType video/divx A31536000
ExpiresByType application/msword A31536000
ExpiresByType application/x-msdownload A31536000
ExpiresByType image/gif A31536000
ExpiresByType application/x-gzip A31536000
ExpiresByType image/x-icon A31536000
ExpiresByType image/jpeg A31536000
ExpiresByType application/vnd.ms-access A31536000
ExpiresByType audio/midi A31536000
ExpiresByType video/quicktime A31536000
ExpiresByType audio/mpeg A31536000
ExpiresByType video/mp4 A31536000
ExpiresByType video/mpeg A31536000
ExpiresByType application/vnd.ms-project A31536000
ExpiresByType application/vnd.oasis.opendocument.database A31536000
ExpiresByType application/vnd.oasis.opendocument.chart A31536000
ExpiresByType application/vnd.oasis.opendocument.formula A31536000
ExpiresByType application/vnd.oasis.opendocument.graphics A31536000
ExpiresByType application/vnd.oasis.opendocument.presentation A31536000
ExpiresByType application/vnd.oasis.opendocument.spreadsheet A31536000
ExpiresByType application/vnd.oasis.opendocument.text A31536000
ExpiresByType audio/ogg A31536000
ExpiresByType application/pdf A31536000
ExpiresByType image/png A31536000
ExpiresByType application/vnd.ms-powerpoint A31536000
ExpiresByType audio/x-realaudio A31536000
ExpiresByType application/x-shockwave-flash A31536000
ExpiresByType application/x-tar A31536000
ExpiresByType image/tiff A31536000
ExpiresByType audio/wav A31536000
ExpiresByType audio/wma A31536000
ExpiresByType application/vnd.ms-write A31536000
ExpiresByType application/vnd.ms-excel A31536000
ExpiresByType application/zip A31536000
</IfModule>
<IfModule mod_deflate.c>
<IfModule mod_setenvif.c>
BrowserMatch ^Mozilla/4 gzip-only-text/html
BrowserMatch ^Mozilla/4\.0[678] no-gzip
BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
BrowserMatch \bMSI[E] !no-gzip !gzip-only-text/html
</IfModule>
<IfModule mod_headers.c>
Header append Vary User-Agent env=!dont-vary
</IfModule>
<IfModule mod_filter.c>
AddOutputFilterByType DEFLATE text/css application/x-javascript text/html text/richtext image/svg+xml text/plain text/xsd text/xsl text/xml image/x-icon
</IfModule>
</IfModule>
<FilesMatch "\.(css|js|CSS|JS)$">
Header set Pragma "public"
Header append Cache-Control "public, must-revalidate, proxy-revalidate"
</IfModule>
FileETag MTime Size
Header set X-Powered-By "Fever Clan"
</IfModule>
</FilesMatch>
<FilesMatch "\.(html|htm|rtf|rtx|svg|svgz|txt|xsd|xsl|xml|HTML|HTM|RTF|RTX|SVG|SVGZ|TXT|XSD|XSL|XML)$">
</IfModule>
FileETag MTime Size
</IfModule>
</FilesMatch>
<FilesMatch "\.(asf|asx|wax|wmv|wmx|avi|bmp|class|divx|doc|docx|exe|gif|gz|gzip|ico|jpg|jpeg|jpe|mdb|mid|midi|mov|qt|mp3|m4a|mp4|m4v|mpeg|mpg|mpe|mpp|odb|odc|odf|odg|odp|ods|odt|ogg|pdf|png|pot|pps|ppt|pptx|ra|ram|swf|tar|tif|tiff|wav|wma|wri|xla|xls|xlsx|xlt|xlw|zip|ASF|ASX|WAX|WMV|WMX|AVI|BMP|CLASS|DIVX|DOC|DOCX|EXE|GIF|GZ|GZIP|ICO|JPG|JPEG|JPE|MDB|MID|MIDI|MOV|QT|MP3|M4A|MP4|M4V|MPEG|MPG|MPE|MPP|ODB|ODC|ODF|ODG|ODP|ODS|ODT|OGG|PDF|PNG|POT|PPS|PPT|PPTX|RA|RAM|SWF|TAR|TIF|TIFF|WAV|WMA|WRI|XLA|XLS|XLSX|XLT|XLW|ZIP)$">
</IfModule>
FileETag MTime Size
</IfModule>
</FilesMatch>
# End Browser Caching/Headers
<FilesMatch "\.(bmp|css|flv|gif|ico|jpg|jpeg|js|pdf|png|svg|swf|tif|tiff)$">
Header set Last-Modified "Mon, 06 Feb 2017 00:00:00 GMT"
</FilesMatch>
</IfModule>
Sorry I should have been more clear too, I mean the vB CMS in the root folder, but if you're using WP then that doesn't apply.
Can you remove the DBSEO htaccess entries from root and put them in the forums folder one instead, and see if that works for you?
Just to double check. This Htaccess that I posted is located at in the root of the forums. feverclan.com/forums/.htaccess -- you would like me to remove the DBSEO part of that htaccess?
Oh, I thought that .htaccess was the root of the site.
Just to double check I've done everything correctly -- not trying to rush. Did you get everything you needed?
I removed the Forum Component URL from the settings, as well as changed the /forums/.htaccess file a little and that appears to have resolved the issue. Can you confirm?
Is it going to fix previously broken URL's? If it is, it doesn't work. If its only for newer threads -- I think it has.
