Bug Features Not Working
EasyEasy
Got a few issues after buying this. Hope we can get them ironed out.
Channel doesn't show when member is online
Channel wont stream after clicking on it. Probably the same as above.
Error code below is given when clicking following url on the main twich page
twitch.php?do=view&channelid=username#stream
Also get the following error when enabled with vbshout.
Fatal error: Call to undefined method VBSHOUT::initDataManager() in /*************/forums/dbtech/twitch/actions/view.php on line 43
Thanks
The experts here will certainly have more insight but it sounds to me like you possibly do not have the name correct for the stream.
As for the shoutbox, well that is the experts department. :)
I know how the stream works as I had the original version installed and working fine.
You need to upgrade your vBShout version, as it's too old to function correctly with this mod.
Since you didn't list an error code in the OP, can you please manually verify that you have the cURL library installed on your server? if you do not, you need to install it, otherwise you will be unable to use this mod.
Update on this.
Notifications are working just takes more than 4/5 mins for them to come through. If you click on the member name and view the channel within the site its fine however the main twitch page takes 4/5 mins to update who is online details and also as mentioned before notifications to come through the PM system.
Update on this.
Ignore this post. Just seen that its set like that for performance issues.
Thanks for your time on this mod. Its fantastic.
Legacy Live Streaming Suite
