Question Custom fields in dbtech_review_review_short?
tavenger5
Is there a way to display custom fields for reviews in the dbtech_review_review_short template? Also, what would be the code for default fields, like address?
For example, I figured out that address is {vb:raw review_data.address} What would the first custom field be? (like {vb:raw review_data.field1} ) Is it even available for that template?
I don't believe you can refer to individual custom fields in the main template, I think it's bundled into one variable that displays a block of all the custom field inputs.
hum, okay. I tried {vb:raw details_data} in that template and it looks like it's not registered there. I don't think that would work anyway since I don't want to display all the data available in that block anyway and the styling would have to to different between the different bits.
Legacy DragonByte Reviews
