Regitze Birketoft
i know enough about the templates to know that you cant just simply remove the title bar... but if you ever find a way - that would be AWESOME!!!! i would love to connect the thank/like/dislike field to the rest of the entry
but can you instead give us the choice between using the color from postbithead_background to using the color from postbit_foot_background...
right now - the thank/like/dislike very easy look like a post all in it self - that would be a fix to make it look more like a part of the actual post...
more maybe just tell me where to find and correct it ?
thanks very much!
thanks very much!
Upvote
