Question Character replacement - how to stop?
subaruclub
I just noticed on my site that characters are being replaced.
Example:
but I’m sure there
That should be "I'm sure there"
Where can I look to fix this?
D.
In the General Rewrite Settings, what is the value of Filter Non-Latin Characters? Also, check if you have Enable UTF-8 turned on while your database/style charset isn't set up for it.
Where are you seeing this issue in action? Could you link me to an affected piece of content?
I have no idea why.... but the problem seems to have fixed itself somehow.
I am seeing posts using the same syntax and they look fine.
Weird
D.
