I've noticed that whenever I do Shift+# it causes the cart to open, as show below. Is there a way to stop this from happening, or is it something I'm doing?? If worse comes to worse, if I could remove the cart from a select "PAGE" that would alleviate the challenge I'm having with it.
You can change the phrase shortcut.dbtech_ecommerce_checkout_menu to another character (must be a single character). I'm not sure what would happen if you blank it out - try it and report back
