rtiindia
Sir,
I am receiving the following errors from Bing webmaster tools after the vbseo-dbseo upgrade. Would you let me know how to solve it?
Canonical tags can be used to help de-dupe URLs for pages with the same or very similar content. Bing has detected that your site is using what appears to be the same canonical URL for a large number of pages that are not the same. This may be indicative of a problem with your HTML template, content publishing system, or site code. You should review the source of your pages and check if the URLs used inside the <link rel="canonical" href="<url>" /> are not accidentally pointing to the same location for all (or too many) pages.
Does it tell you what pages it believes are different? As far as I know, canonical URLs are currently accurate.
Sir,
I am repeatedly getting this error over the webmaster tools and without your assistance, I may not be able to go further. When it says 'large number', i ma presuming that it's systemic and site wide.
What they are probably referring to is a thread with lots of posts seeing the same canonical URL for all individual post links on that page. It's completely normal. There's nothing to indicate that DBSEO is generating incorrect canonical URLs.
Tags Tags
db error
