Bug Bookmark post doesn't work unless Bookmark Thread is also enabled.
thj
I wanted to have Can Bookmark Threads set to No and Can Bookmark Posts set to Yes, but when doing so, despite the bookmark icon/button showing on posts, it doesn't do anything when clicked. If I set Can Bookmark Threads back to Yes then the bookmark post icon/button does work.
My skin is essentially the default skin with stylevar changes to alter the appearance; however, the same behavior is seen when using the unaltered default style.
Is this expected behavior or a bug?
thj
This probably isn't the best way to do it, but a patch like this applied to upload/dbtech/bookmark/hooks/showthread_complete.php appears to fix the issue:
--- dbt/showthread_complete.php	2017-03-05 09:56:43.000000000 -0700
+++ thj/showthread_complete.php	2017-03-05 10:00:58.000000000 -0700
@@ -1,19 +1,26 @@
 <?php
-if ($vbulletin->userinfo['userid'] AND ($vbulletin->userinfo['permissions']['dbtech_bookmarkpermissions'] & $vbulletin->bf_ugp_dbtech_bookmarkpermissions['canbookmarkthread']))
+if ($vbulletin->userinfo['userid'] AND
+			($vbulletin->userinfo['permissions']['dbtech_bookmarkpermissions'] & $vbulletin->bf_ugp_dbtech_bookmarkpermissions['canbookmarkthread']) OR
+			($vbulletin->userinfo['permissions']['dbtech_bookmarkpermissions'] & $vbulletin->bf_ugp_dbtech_bookmarkpermissions['canbookmarkpost'])
+	if ($vbulletin->userinfo['permissions']['dbtech_bookmarkpermissions'] & $vbulletin->bf_ugp_dbtech_bookmarkpermissions['canbookmarkthread'])
 	$templater = vB_Template::create('dbtech_bookmark_thread');
 		$templater->register('threadid', $thread['threadid']);
 		$templater->register('hasBookmarked', (int)is_array($db->query_first_slave("
 			SELECT userid
 			FROM " . TABLE_PREFIX . "dbtech_bookmark_entry
 			WHERE contenttype = 'thread'
 				AND contentid = '" . intval($thread['threadid']) . "'
 				AND userid = '" . intval($vbulletin->userinfo['userid']) . "'
 	$template_hook['showthread_above_posts'] .= $templater->render();
 	// Begin list of JS phrases
 	$jsphrases = array(
 		'dbtech_bookmark_bookmark_thread'	=> $vbphrase['dbtech_bookmark_bookmark_thread'],
 		'dbtech_bookmark_unbookmark_thread'	=> $vbphrase['dbtech_bookmark_unbookmark_thread'],
Fillip H.
Staff member
Owner
Developer
I had problems applying the .patch file but I manually integrated the changes for you in the current release. Thank you :)
Company Information
Staff member
Company Info
Hello thj,
Thread / Post Bookmarking
