Bug Ajax function does not work
katoona
I think I have set it up correctly, but if I click one of the buttons the ajax function does not work, and I have to refresh the page to see the results of the click. It could be a conflict with another mod, but I have tried to turn everything off, and still does not work.
Has this happened to someone else?
You have a mod interfering with your registration process, causing a blank page. You should add
ini_set('display_errors', true);
to your config.php file and then attempt to register a new user yourself to see what the error is :)
I tested the thanks mod on your forum and I had no problems with the AJAX process, the click appeared just fine without requiring a reload :)
It is a conflict with Sphinx search - strange, since you use the same search engine. When I disabled it the Thanks Ajax function started to work.
We use the DigitalPoint Sphinx Search - not the vBulletin one from vb.org - if that makes a difference.
