Question a couple of problems after installing DragonByte SEO Pro
horseguards
I have a couple of problems after installing DragonByte SEO
1. Activity Stream
the url showing in the activity stream are vBulletin urls
https://www.diigo.com/item/image/4mzth/41nt
2. I have several "Forum" with no content, just to separate the content, and the I have sevearal subforums.
In a couple of forums, one subforum has the same name as the forum. After installing DragonByte SEO, I can't
seem to access these subforums.
https://www.diigo.com/item/image/4mzth/t340
Could you please be so kind as to give me a hand with this?
thank you!
This is because these URLs are loaded via AJAX. Don't worry, search engines won't see them.
This will happen if you do not have [forum_id] as a part of your forum URLs. It is entirely impossible to do anything about this, you must either add forum IDs to your forum URLs or rename the forums.
Please try clicking Clear System Cache in the DBSEO AdminCP, then refresh the forum page, see if that helps :)
