Question why is it not possible caching vba modules?
I'll have to look into this one for you as there are a few issues we need to work around with the development of vBOptimise. This may have been caused by a change in vBAdvanced that caused the function to break or Deceptor may have simply decided to remove it. I'll look into it non-the-less!
works now... somehow?
anyways the problem is solved.. i changed from filecache to ACP caching..
and its caching now..
thanks anyways!
great support
