Hi
I am testing the VBSlider Lite version before boy the pro version.
I want to know if I can add manually the variable to place to Slider in any template / place.
I trayed to put the {vb:raw show.vbslider_instance1} but dont works, the format {vb:xxxxxx} is complatible with 3.8.5??? Becouse I think that its only works en VB4.
PLEase, answer me to know if I can add the Vbslider manually and wich is the variable for VB 3.8.X complatible.
BEst Regards!!!!
Sergio
BEst Regards!!!!
Sergio
