Bug There are 2 positions of dialog of rating!
djFarsang
There are 2 positions of dialog!
There are 2 positions of dialog rating! following by fig.
That might be another mod causing that, can you disable your other mods 1 at a time to see if one of them is causing that?
Aah, my bad I was looking at related thread mods that were causing problems, didnt spot that one, glad you found it bro.
For now, you can workaround it by doing this:
ACP->Plugins & Products->Plugin Manager
Find the plugin called Thread View Insert and click Edit
Change the hook location to postbit_display_complete and the execution order to 15 then click Save
Should display correctly after that.
I'll work on figuring out what's causing the conflict.
Ok., It worked, Thank you very much.
Legacy Thread Ratings
