Switch to vBNavTabs?
Rick
On our 4.2.0 site, we have been using Andreas' Navmanager Enhancements.
Could you please look at the NavBar on our site and tell me if I can replicate
that using vBNavTabs? As you probably know, Andreas' mod is no longer
supported as of 4.2.1 so we need to find another solution.
Dropdown on rollover would be a welcome option but not required.
Rick
I was concerned about the slide over dropdowns like:
File Library -> Specialty Searches ->Top 100 Files of the Year.
Hmmm, Is there any chance you could add an "html item" like NavMan had. It is basically the same as a link
but it lets you put in html code instead and thus lets you create your own little submenus by adding the right
html code. Then my project is doable. Of course I wouldn't object to another "menu item" instead of the "html
item", whichever works best for you. Thank you for your consideration.
Rick
