Legacy Statistics in forum whats going on
MrKing
Statistics in forum whats going on would be great feature.
Download Statisics
Downloads Available: 1234
Categories: 123
etc
also i would like to be able to place the stats on custom areas
so if i wanted to place say the total downloads like in the stats sidebox what code would i use?
<p>{vb:rawphrase downloads}: <span style="font-weight: bold;">{vb:var stats.files}</span></p>
does not work on forum header / homepage.
Thanks
Download Statisics
Categories: 123
etc
Thanks
That wont work anywhere else besides on a downloads generated page because it's not globally set. On the forumhome it doesn't load the download phrases and doesn't set the variables up.
i see, can i set it globbaly or is there another code i could use to call a the sql field to any page?
Thanks
Thanks
You could create a plugin, but it's not just a sql field, it's a query and calculate that's done on the main download page. So you'd have to reproduce the same code in the plugin.
Legacy vBDownloads
