Question redirects partially work
xenigma
Hi,
I have the vb suite installed at: mysite.com/forum. The following urls redirect correctly to the HTTPS:// versions:
www.mysite.com/
mysite.com/
mysite.com/forum/forum.php
However:
www.mysite.com/forum/forum.php does not redirect to HTTPS://
In my htaccess (located in home/public_html) I have:
#HTTP to HTTPS
RewriteCond %{HTTPS} off
RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
#Non-WWW to WWW
RewriteCond %{HTTP_HOST} ^mysite.com$
RewriteRule (.*) https://www.mysite.com$1 [R=301,L]
Any ideas why that one redirect doesn't work?
Also, prior to DBSEO I had a redirect in VBSEO for forum.php to /forum/. Is that possible with DBSEO? I'm guessing that it is but a redirect in htaccess has no effect so is the setting somewhere in DBSEOCP?
Also, possibly(?) related to the above, some users are reporting the following when they login:
"Invalid Redirect URL (https://www.mysite.com/forum/)"
Thanks
Just a quick addition: setting "Force Forum Directory Index" to "yes" does not strip out forum.php from the url when I click on the forum tab. Actually it makes no difference whether I have that set as "yes" or "no".
Sorry, is that the complete contents of your .htaccess file? If so, the reason why nothing is working is because the DBSEO rewrite rules are missing from the .htaccess file :)
:) No of course not. I only copied the rules that were relevant to my question. The DBSEO rules are in a htaccess in /forum. I have the other htaccess in the root. DBSEO works great apart from the stuff I mentioned above.
For the forum.php to /forum/, you can turn on "Force Forum Directory Index" in order to remove forum.php
The http to https, I don't think that's related to DBSEO?
Here's our .htaccess file:
	# Force SSL:
	RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
	# Force www:
	RewriteCond %{HTTP_HOST} !^$
	RewriteCond %{HTTP_HOST} !^www\. [NC]
	RewriteCond %{HTTPS}s ^on(s)|
	RewriteRule ^ http%1://www.%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
As I mentioned above, setting "Force Forum Directory Index" to "yes" does not strip out forum.php from the url when I click on the forum tab. It makes no difference whether I have that set to "yes" or to "no".
Yes, I concede that DBSEO should not be causing the failure of "www" to redirect to "https://www". All I can say is that it was working correctly before DBSEO.
If I put my (or your) WWW/SSL rules into my htaccess in public_html and then open www.mysite.com/forum/forum.php it redirects to https but the url changes to:
https://www.mysite.com/forum/dbseo.php?dbseourl=forum.php
If I move those rules to the htaccess at /forum then entering www.mysite.com/forum/forum.php results in that being the url that loads.
What's happening there?
Sorry, I've been very busy with other projects this week, I'll post back when I have more information. Sorry for the delay :(
This is because the "Script Name for Forum Home Page" setting in the vBulletin Options. When I corrected this setting, it works as intended.
I applied my WWW/SSL rules and the redirect works as intended without the issue you describe.
I placed the rules in both .htaccess files.
Hey,
https: // mysite dot com /forum/ produces a 403 now. Adding forum.php to that redirects to /forum/ which 403s
I've turned the forum off until this works.
Someone turned off indexes in the .htaccess file and removed the index.php file that would tell the site to load the forum. I have reverted these changes and the forum now works as intended.
Cool. I made the indexes change a few days ago because it was possible at that point for guests to view the contents of the /forum/ directory.
Many thanks for your help. Much obliged!
Hello xenigma,
