Question Raffle entries and Currency from DB Activity & Awards plug-in.
admin1980
Hi Support,
I have the DBRaffles(Lite) and DBActivity&Awards(pro) Plugins. I would like my users to be able to trade their points for raffle entries.
Q. Is it possible to use the points collected from DBActivity as a currency? If yes, can you please explain how it can be done?
Q. Will a user's total points in DBActivity decrease as they are traded in for raffle entries?
Great products. Thank you!
1. Add a new currency and use user as the points table and dbtech_vbactivity_points as the points table
2. Yes, but their activity level won't decrease.
I dont know what Im doing wrong, I cant see the link to purchase a raffle entry. I know it should display under the "you entries" text, but I cant get it to display.
Thanks.
Did you make sure to change the currency your raffle's entry cost is charged in?
I updated the default currency, I did not create a new one. Could that be the issue? Here are my settings:
Thanks.
Sorry for the delay, I've checked this @ your site and the problem appears to be that no usergroups have been configured to be able to enter raffles. Please use vBulletin's Usergroup Manager and edit each usergroup to grant them this permission :)
Hi Fillip H.,
Thanks for checking but I still cant get the link to appear, I already made the change to the User Groups but nothing. My site is not live yet, feel free to make the change yourself if needed to verify this is working. Thanks.
Hi Fillip H., can you please assist? I completely understand you must be swamped running your site/business but it's bee 24 days since I reported this issue. Can you please go in and make the necessary changes the the plugin settings for this to work?
Hi Fillip H.,
I'm really sorry, I'm not sure how I managed to miss this ticket :(
I'll look into this straight away :)
Update: I re-enabled the navbar tab, but now your site loads to a blank page so I can't test this further.
HI Fillip H., I fixed the blank page issue. It was one of the plugins i had disabled, not compatible with the site and caused that problem.
Please go a head an take a look when you have a moment.
I can't find any FTP information from you, and this is needed in order to debug this issue further.
Legacy DragonByte Raffles
