Bug Integration with DBSEO issues
Carpesimia
Ok, this works fine most of the time. The issue is with the postbit and the part that collapses it.
If you reply to a post, and then on that next page, click the postbit to unhide the information, the page has issues. This is because the postbit hide/unhide button has this url:
www.psx-place.com | 404 - Page Cannot Be Found
whereas it SHOULD have:
PSX Place
This error only happens on the page DIRECTLY following a reply.
I have a second issue but I'll post a separate message for it.
I'm assuming you're trying to expand the menu directly after posting a post with Quick Reply? That's not going to work regardless of whether DBSEO is installed, the page must be reloaded before that menu becomes expandable.
