Question Increase post bit margin
Goshee
Hi! :)
Okay I was wondering if there was any way to increase the margin on the postbit. Here is an example.
What it is like now -------> What I want it to look like
I need to get the Likes stat in line with everything else, any help would be appreciated!
The template that holds the wrapper for the stats is dbtech_thanks_postbit - I don't know how specifically to do what you need it to do so that's the best I can give you as far as pointers unfortunately :(
Thanks I managed to figure it out, I'll share the code in case anyone else might find it useful.
In the template:
Template: dbtech_thanks_postbit
Simply add this line of code to the very top of the template
<div style="padding-top: 0px; padding-left: 0px; padding-right: 0px; padding-bottom: 0px;">
Then add this code to the very bottom of the template
</div>
You can change the values of "0px;" to whatever you want.
