Question HTTPS issue "Blank Screen
Ryan Hunter
Hello I noticed I'm getting the Blank Screen on the Twitch channel using Stream Suite, that wotws had. The SSL was given to me free as a long time customer loyalty by OVH. How to fix this HTTPS issue?
If you are receiving a fully white screen, with no content, that indicates a PHP error. Please make sure display_errors is turned on in php.ini.
I'm not ignoring you but my Host Service is taking a while to reply, because I cannot seem to find the PHP Config menu from my Shared Hosting Control Panel.
In that case, you'll need to inspect your PHP error log for whatever error message is causing this.
(And you should probably also look for a better host :P)
Hello Ryan Hunter,
Legacy Live Streaming Suite
